Low compression no start help.
I bought a no start civic.
I got a new battery and it will crank good.
I did a conprrssion test and got
60-50-50-120
No mixed coolant or oil, no other symptoms...
Could a bad HG do this-make car loose 100 psi-If so could I see it when cranking engine with rad cap off?
Also valves are good as it just got a new HG and valve...(according to previous owner)
Could bad timing do this? Would it make any conpression if timing was off?
Any advice greatly appreciated.
60-50-50-120
60-50-50-120
60-50-50-120
Whatever the previous owner said is all bs unless you know and trust the guy or you have actual receipts from a shop.
As stated above, first thing to do is a leakdown test.
Post your results!
Dynosur
Feb 6, 2013 04:08 AM
Jimmy
17
Jul 27, 2010 01:30 PM
