98 ex d16y8 over heating
Old Nov 20, 2014 | 10:08 AM
lilfed857's Avatar
Default 98 ex d16y8 over heating
My 98 ex is overheating only when I drive and the heat is off. I can not figure out why I just put a new tranny In it and now it's over heats. Any ideas?
Old Nov 20, 2014 | 10:32 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: 98 ex d16y8 over heating
Did you bleed the coolant of air properly?
Old Nov 20, 2014 | 11:34 AM
Koko4's Avatar
Try bleeding the air out of the system by taking your radiator cap off (when completely cold, obviously), and running the engine. See if the fluid "burps" out a couple of times. Keep an eye on the radiator fan to make sure it's cycling on/off, and also check to make sure that both hoses get equally hot once the thermostat opens up.
It's going to be something simple..trust me.
Old Nov 21, 2014 | 07:01 AM
lilfed857's Avatar
Alright guys I tried to "burp" the system and it seems to have worked but I am from central ny and driving with my heat off is a struggle but I have it a shot it usualy overheated on my from my apart to the gas station which isn't a far drive 5or 10 mins round trip so I started it and let the car warm up and drove to class and sat there over 10 mins total of the car running without heat on and my needle went to half way and stayed there. So I think I am good I will keep you updated and ask any questions if I find anything else
Old Nov 21, 2014 | 07:08 AM
tony_2018's Avatar
Fish Twig
Did you bleed the system with the heater on?
Old Nov 21, 2014 | 07:19 AM
09chaplak's Avatar
Loves Tossing Salad
Will OP fall into the trap?! Stay tuned to find out!!
Old Nov 21, 2014 | 12:54 PM
Koko4's Avatar
Is proper procedure to bleed it with heater on or off?
Old Nov 21, 2014 | 01:13 PM
09chaplak's Avatar
Loves Tossing Salad
The suspense builds......
Old Nov 21, 2014 | 04:05 PM
92ehatch's Avatar
Lets say the heater core is empty...you bleed it with the heater turned to cold...then you drive and turn the heater on..where does that air go? Back into the rest of the system.
Yes bleed with mixer set to hot
Old Nov 21, 2014 | 04:14 PM
NotARaCist's Avatar
I never narc'd on nobody!
Yep. You don't even have to turn the fan on, just make sure the temperature slider is all the way hot. That'll open the valve and let coolant circulate through the ENTIRE system.
crazed4macs
Oct 6, 2014 06:25 PM
AllAboutHonda
Dec 11, 2011 05:31 AM
Exitialis
Honda Civic (2001 - 2005)
Apr 25, 2009 11:00 PM
briq4
Mar 4, 2006 02:10 PM
flood
Dec 5, 2005 06:21 PM
