Temp Gauge Fuckery
Old Nov 18, 2014 | 10:43 PM
EF_SEDAN_LOVER's Avatar
Default Temp Gauge Fuckery
My temp gauge reads all the way cold even though my heat is blowing hot. Sometimes it reads normal operating temp while I'm driving and if i turn the heat on it drops all the way back down to cold. Suggestions????
Old Nov 19, 2014 | 05:47 AM
Former User's Avatar
Default Re: Temp Gauge Fuckery
Car? Engine?
Replace the thermostat and bleed the cooling system. Then go from there.
Old Nov 19, 2014 | 06:23 AM
91 EF sedan w/ Mini Me. Thanks for the tip. I thought it might be thermostat i just wanted another opinion.
Old Nov 19, 2014 | 02:12 PM
F22Master's Avatar
Probably a loose connection/break in the wire between the gauge and the sensor. The temp sensor is a 1 wire sensor on the left/passenger side of the head directly under the distributor.
Old Nov 19, 2014 | 06:00 PM
Doh!'s Avatar
Definitely check that the sensor is connected properly. The clips that hold the wire on become brittle over time due to heat.
Old Nov 20, 2014 | 09:35 AM
Thanks F22MASTER. That makes sense because the heat works perfect, its just the gauge that has a mind of its own.
Old Nov 20, 2014 | 11:26 AM
This^ makes me think the gauge and sending unit are not the cause and that it's a cooling system problem.
Old Nov 20, 2014 | 03:24 PM
F22Master's Avatar
If the heater is blowing hot, then the temp gauge should be at least 1/4 of the way up the scale.
If the heater is blowing hot, and the temp gauge is below that, you have a guage/sensor/wiring problem.
Old Nov 20, 2014 | 04:06 PM
Not necessarily. For example, air trapped in the cooling system could cause the temp gauge reading not to correspond to the actual coolant temperature, and also cause the reading to register correctly only intermittently.
dlx111
May 10, 2018 09:57 PM
DRatedA.W.D.
18
Dec 14, 2011 10:10 AM
eth0r
Nov 10, 2005 03:31 AM
HamiltonRex
Oct 6, 2004 01:32 PM
erniecars
Jun 14, 2002 11:48 PM
