93 del sol wont crank
Old Nov 16, 2014 | 01:30 PM
teamleader's Avatar
Default 93 del sol wont crank
hi,i just bought a 93 delsol si, it has been siting for 5 years in someones driveway.I pulled the gas tank,put in a new fuel pump,If i turn the key everything cuts on but wont start.no noise at the starter.I can can start it if i run a cable from the battery to the solenoid.any ideals?
Old Nov 16, 2014 | 01:33 PM
Former User's Avatar
Default re: 93 del sol wont crank
Check rubber stopper at the top of the clutch pedal. Did it fall out?
Old Nov 16, 2014 | 02:08 PM
teamleader's Avatar
Default Re: 93 del sol wont crank
no it still has stopper,gets fuel ,that would mean the main relay is ok ,right?
Old Nov 16, 2014 | 02:11 PM
The clutch pedal has two separate switches if the car has cruise control. You're interested in the topmost stopper/switch.
The main relay has nothing to do with the starter.
Test the clutch pedal switch that presses on the rubber stopper.
Old Nov 16, 2014 | 02:30 PM
teamleader's Avatar
That was it man !!!! I didnt see that top switch.You nailed it !!! Thanks RonJ@HT
donnieb22000
12
Oct 22, 2016 09:13 AM
luther
Sep 13, 2012 11:08 AM
superdan50
11
Mar 25, 2011 09:36 PM
binarypunk
Aug 7, 2007 05:25 PM
underpressure02
Jan 7, 2006 02:15 PM
