Ideal AFR for B16A
Old Nov 15, 2014 | 06:04 AM
gabrielsousa's Avatar
Default Ideal AFR for B16A
whats the ideal AFR for B16A for power ?
is 12.8:1 - 13.2:1 ?
my compression is :
cylinder 4 - 11.5
cylinder 3 - 12.5
cylinder 2 - 11.5
cylinder 1 - 12.5
Old Nov 15, 2014 | 07:32 AM
Default Re: Ideal AFR for B16A
Old Nov 15, 2014 | 01:15 PM
VegasInvasion's Avatar
I'm Huge In Japan
your compression is awful... like, pretty sure you have some bad rings, ring lands, or a leaking head. your AFRs are not actually going to be accurate with an 8% variation per stroke. You should sincerely consider an overhaul before you bother tuning.
But I would go about 0.4 richer in the last 4 columns regardless.
If you graph it and find it makes more power leaner, that's great, but especially with how wonky your compression is I doubt it would make any gains.
At this point you're just trying to avoid detonation.
Old Nov 15, 2014 | 01:25 PM
English isn't my native language.... whats that ?
Old Nov 15, 2014 | 03:14 PM
spAdam's Avatar
Loved
Community Favorite
my compression is :
cylinder 4 - 11.5
cylinder 3 - 12.5
cylinder 2 - 11.5
cylinder 1 - 12.5
Something is wrong, those compression numbers don't make any sense. What units are you using?
Old Nov 15, 2014 | 04:26 PM
stock b16a1 engine , 300.000 km
Old Nov 15, 2014 | 06:22 PM
Muckman's Avatar
Moderator in Chief
What unit of pressure is your compression test? BAR? kg/cm2?
Old Nov 16, 2014 | 03:40 AM
dont know it was not me who did it
Old Nov 16, 2014 | 05:33 AM
motoxxxman's Avatar
yeah those compression values really don't make sense, it's almost impossible to have those values be so perfectly inconsistent like that
Old Nov 16, 2014 | 06:32 AM
what are the standard values, and what unit ?
Old Nov 16, 2014 | 01:33 PM
PyroProblem's Avatar
Gotta be in Bar. 12 Bar = about 176 psi
11.5 bar = about 162 psi.
The engine doesn't have great compression numbers but there not super horrible either. Depending who and how they did the compression test, the numbers May not be 100% either.
Old Nov 20, 2014 | 04:37 PM
Standard…………………… 187 psi
Minimum…………………… 135 psi
Max. variation…………… 28 psi
is this right ?
Old Nov 20, 2014 | 06:37 PM
F22Master's Avatar
That is correct
goldegg
Nov 11, 2006 09:06 AM
b16acrxer
Oct 19, 2003 02:43 PM
Hybridize
Sep 22, 2003 03:12 PM
ejprimo
Apr 28, 2003 01:25 PM
bryman10
Mar 25, 2003 07:39 PM
