clunking/popping noise from suspension or steering
Old Nov 14, 2014 | 07:59 PM
skaternak's Avatar
Default clunking/popping noise from suspension or steering
i have a 2000 ex coupe. everytime i take off or almost come to a complete stop i hear a clunking noise. Also when i am moving slow like in a parking lot and I turn it makes the noise again. I can feel it in my feet and the floor sometimes. I get scared cause it feels like my car is gunna come apart sooner or later. I've changed inner and outer tie rods. lower and upper balljoints. wheel bearings. but the noise is still there. i've heard the rack and pinion bushings should be checked also. i've looked and found no write up on the rack and pinion and i've lost my haynes manual and cant afford to buy a new one. its a power steering system. any help is much appreciated.
Old Nov 14, 2014 | 09:00 PM
MisereNoire's Avatar
Default Re: clunking/popping noise from suspension or steering
Firstly, forget the Haynes manual. download the Factory Service Manual for your vehicle and start from there.
Old Nov 14, 2014 | 09:28 PM
skaternak's Avatar
where do i download that from?
Old Nov 14, 2014 | 10:22 PM
Well, a simple search would have gotten you that answer....
Last edited by TomCat39; Nov 15, 2014 at 09:25 AM. Reason: linking to copyrighted material is against TOS. link removed.
Old Nov 15, 2014 | 03:43 AM
92ehatch's Avatar
Have you tried checking the axles and bushings up front for tears?
Old Nov 15, 2014 | 06:00 AM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Was your car making the noise before you replaced the tie rods and ball joints? Did it start making the noise after one of the replacements? Did you replace the tie rods and ball joints at different times or all at the same time?
Do you get a clicking sound when turning? Does the sound happen on flat, smooth roads or only on rough surfaces/speed bumps?
What have you already done to try and find the source of the noise?
eH.
Old Nov 15, 2014 | 06:48 AM
tony_2018's Avatar
Fish Twig
First of everything else!!! Get your *** under the car and take pics, look around for anything that might look out of place, loose, ripped boots, etc..e.tc...etc.e.te.c.et.ec...
DohcVtec77
Sep 2, 2016 06:15 PM
rovafa2002
Feb 21, 2014 11:11 AM
theeogflip
Mar 24, 2008 01:03 PM
dragaholic
Suspension & Brakes
Nov 19, 2005 06:07 PM
I8ayellowcrayon
May 10, 2005 08:03 AM
