clunking/popping noise from suspension or steering
Old 11-14-2014, 07:59 PM
skaternak's Avatar
Default clunking/popping noise from suspension or steering
i have a 2000 ex coupe. everytime i take off or almost come to a complete stop i hear a clunking noise. Also when i am moving slow like in a parking lot and I turn it makes the noise again. I can feel it in my feet and the floor sometimes. I get scared cause it feels like my car is gunna come apart sooner or later. I've changed inner and outer tie rods. lower and upper balljoints. wheel bearings. but the noise is still there. i've heard the rack and pinion bushings should be checked also. i've looked and found no write up on the rack and pinion and i've lost my haynes manual and cant afford to buy a new one. its a power steering system. any help is much appreciated.
Old 11-14-2014, 09:00 PM
MisereNoire's Avatar
Default Re: clunking/popping noise from suspension or steering
Firstly, forget the Haynes manual. download the Factory Service Manual for your vehicle and start from there.
Old 11-14-2014, 09:28 PM
skaternak's Avatar
where do i download that from?
Old 11-14-2014, 10:22 PM
Well, a simple search would have gotten you that answer....
Last edited by TomCat39; 11-15-2014 at 09:25 AM. Reason: linking to copyrighted material is against TOS. link removed.
Old 11-15-2014, 03:43 AM
92ehatch's Avatar
Have you tried checking the axles and bushings up front for tears?
Old 11-15-2014, 06:00 AM
yippee-ki-yay
eHMxhACk's Avatar
Was your car making the noise before you replaced the tie rods and ball joints? Did it start making the noise after one of the replacements? Did you replace the tie rods and ball joints at different times or all at the same time?
Do you get a clicking sound when turning? Does the sound happen on flat, smooth roads or only on rough surfaces/speed bumps?
What have you already done to try and find the source of the noise?
eH.
Old 11-15-2014, 06:48 AM
Fish Twig
tony_2018's Avatar
First of everything else!!! Get your *** under the car and take pics, look around for anything that might look out of place, loose, ripped boots, etc..e.tc...etc.e.te.c.et.ec...
DohcVtec77
09-02-2016 06:15 PM
rovafa2002
02-21-2014 11:11 AM
theeogflip
03-24-2008 01:03 PM
dragaholic
Suspension & Brakes
11-19-2005 06:07 PM
I8ayellowcrayon
05-10-2005 08:03 AM
Quick Reply: clunking/popping noise from suspension or steering
