High Mileage CRV - Anything to look for?
Im looking to buy a 98 CRV with 219k Miles for a winter vehicle.
1998 crv. honda
Anything in particular to look for?
1998 crv. honda
Maintenance records? Visual of the car for rust, oil leaks, transmission leaks, if its awd take a look at the differential.
Its really alot to look at for a car with that many miles.
Check for any recalls.. I jus got me a 98 crv for a dd w/255k. and call honda up and I had 2 safety recalls..
1. A wire harness upgrade
2 ignition harness ..
So honda replaced them both free of charge
That post link is deleted. Was the car already sold? Is it a AWD CR-V? Make sure the AWD is engaging properly. If its a car from the snow belt, I would inspect the brakes lines that run under the center of the car.
My brakes lines rusted and were leaking and it was a expensive fix. Around $700. The lines are behind a plastic bracket.
Yep its the 5 speed ex. I picked her up for 2100. The car is extremely clean. 1 owner, maintained very well with all services records from local Honda dealership.
Timing belt was replaced at 105k.. thoughts about doing it again at 219k miles?
I think the interval is at every 105k and so is the water pump. Maybe have them checked out. Though when I did my pulled my water pump, it looked completely tip top. But you just never know.
Here's what I would do since you can't just guess what the previous owner did:
valve adjustment
replace transmission oil - honda MTF
change oil
change Dual Pump fluid in rear diff
Flush clutch fluid
Flush brake fluid
Inspect front upper & lower balljoints
Inspect tie rod end links
Replace cabin air filter
Replace spark plugs (use NGK's)
might as well replace the following since its in the interval:
Timing belt, water pump, tensioner (if you're doing this, might as well drain antifreeze and replace thermostat. catch and reuse the antifreeze if it's clean if not replace)
These are the things I would do but it's a long list when it comes to some of it and it's all basically your wear items or items of concern on a 220k mile vehicle.
valve adjustment
change oil
Flush clutch fluid
Flush brake fluid
valve adjustment
change oil
Flush clutch fluid
Flush brake fluid
valve adjustment
change oil
Flush clutch fluid
Flush brake fluid
franny0510
10
Apr 22, 2014 01:36 PM
dbstrat
Jul 15, 2007 08:07 PM
