93 Civic DX - Acceleration Issue
Old Nov 14, 2014 | 08:53 AM
joevtoo's Avatar
Default 93 Civic DX - Acceleration Issue
Not sure how to exactly describe this. 93 Civic DX 5-speed. As I accelerate from a stop, if I press down on the gas the way I normally would, not flooring it, but not babying it, the engine seems to hesitate--like it's either not getting enough gas or getting too much. If I let up on the gas, the power picks up and then I can accelerate---until the next gear. More noticeable in 1st and 2nd than 3rd and 4th. Hot or cold engine doesn't seem to matter, though the cold weather seems to have helped marginally.
Thoughts about what I should be checking out?
Thanks.
Old Nov 14, 2014 | 08:54 AM
Former User's Avatar
Default re: 93 Civic DX - Acceleration Issue
Last tune up?
CEL codes?
Old Nov 14, 2014 | 09:32 AM
joevtoo's Avatar
Just set the timing, adjusted valves, and replaced the plugs a week or so ago.
Replaced entire throttle body (not a new part) to correct a wandering idle.
But was having the acceleration issue before all that.
Didn't pull CEL codes.
Old Nov 14, 2014 | 09:54 AM
Plug wires, cap, and rotor?
Jump the service connector to check.
Old Nov 14, 2014 | 11:15 AM
joevtoo's Avatar
Default Re: 93 Civic DX - Acceleration Issue
Will do.
Thanks.
makerboom
Apr 16, 2015 11:46 PM
mhernandez
10
Aug 7, 2013 06:16 PM
90sevencoupe
May 9, 2009 06:20 AM
