Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2013 Civic Si Intake Install
Old Nov 14, 2014 | 05:58 AM
agentfazexx's Avatar
Default 2013 Civic Si Intake Install
I installed my DC Sports intake last night on my '13 Si. The hose that comes off the crank case and into the intake did not have any clamps for it, and the directions do not mention putting clamps on either end of that hose. I have seen other installs where they have clamps. Is this normal to not have clamps on this hose?
Here is the intake as it is now:
Old Nov 14, 2014 | 07:14 AM
vtecnique69's Avatar
Default Re: 2013 Civic Si Intake Install
Short term, you'll be OK. Just get some hose clamps as soon as you can to be safe.
Also, you might want to trim down that breather hose about an inch. It looks pinched.
Old Nov 14, 2014 | 07:17 AM
What size clamps do I need for the breather hose?
What is happening if it is in fact pinched?
Anything else look off about my install?
Old Nov 14, 2014 | 06:19 PM
Bwill9886's Avatar
This. Just measure the breather hose diameter and buy accordingly.
Otherwise looks like every other pipe-and-filter SRI available.
Old Nov 15, 2014 | 06:35 AM
Cool thx.
So if the breather hose is pinched like that, what happens? Just curious.
Old Nov 15, 2014 | 11:47 AM
97emsedan's Avatar
You end up getting air infused oil trapped in your valve cover that will eventually clog the line. It is supposed to allow excess crank case vapours out and into the intake air stream to get burned off in the chambers.
Let this pinch stand for too long and you could low seals R create leaks.
Old Nov 15, 2014 | 01:32 PM
I cut off like an inch and now it seems to fit with no kink.
If anyone can tell me what size clamps I need, it'll help
Old Nov 15, 2014 | 05:28 PM
97emsedan's Avatar
The standard 3/4" or 7/8" diameter hose clamps found at any hardware or automotive parts store will do.
Old Nov 16, 2014 | 05:15 AM
Autocraft Carbon Housing Micro-Gear Hose Clamp, 5/16" Band, 5/16" to 7/8" Range (4-Pack) AC5203V: Search no more for the best Hose Clamp at Advance Auto Parts
5/16"-7/8" inch. Think that'll work?
Old Nov 16, 2014 | 08:55 AM
97emsedan's Avatar
The Majestic Honda site says 12.5mm or half inch. Grab the Autocraft one you mentioned, one for each end.
Can't go wrong with those.
Old Nov 16, 2014 | 10:20 AM
That seemed to work. That hose isn't going anywhere.
Average gas mileage has already dropped .1 mpg since Thursday. That's a little concerning to me
Old Nov 17, 2014 | 09:43 PM
m_shake's Avatar
More air=more fuel. Also most intakes can make the maf reading to be off without tuning.
Old Nov 18, 2014 | 04:23 AM
True, and it's chilly now so that probably affects gas mileage in a negative way with a SRI.
What sort of tuning?
Old Nov 18, 2014 | 07:22 AM
m_shake's Avatar
Hondata flash pro is what you need.
Old Nov 18, 2014 | 07:32 AM
Hondata? I can't justify $700 for 36hp...lol
Marksri
Feb 4, 2006 06:39 AM
ginlv888
Feb 20, 2005 06:19 PM
Junchoon
Jan 27, 2004 04:51 PM
Rick
Aug 26, 2003 10:54 PM
