Problem Valve IAC D15B JDM EG8
The engine is running very badly. pause during accelerations.On the tool shows error 14 IAC valve.I cleaned valve but in vain.I changed valve but it also makes.There are days in which the engine operates correctly without being lit error in the dashboard, especially at night when the temperature outside drops. Machine is Honda Civic ferio D15b vtec JDM 1992 .need help! thank you
Use a multimeter to test the two wires in the IACV connector for voltage and ground.
Code 14 is generally produces idle problems. What are they?
Or is the CEL code actually 10 and 4? ...or 1 and 4? ...or 41? Post a video.
My tester shows error 14 System Fault IAC
Yes is there idle problem.
-i posted here because it is a mystery for me also.I was at service and they told me that it`s the error 14. Not 10 and 4 . (tonight i drive and car went well not errors,but during the day i think that error is ON because of the outside temperature)
When the engine is warmed up and the idle is high, remove the intake system. Then use your finger to cover the hole inside the throttle body leading to the FITV. Does the idle speed drop?
Next, do the same test for the hole inside the throttle body leading to the IACV.
thank you for your advice .I will try and after I'll answer here.
I tested the both ideas.the problem is only at IACV.when i put my fingher to cover the hole for iacv everything become normall.what can i do ?
Did you already clean the IACV? If so, test whether the 2 wires in the IACV connector have battery voltage and ground. Also, Ohm test the IACV itself.
If those are fine, next test the ECT sensor and the TPS.
Contact ON
-Battery 12,30v
-Iacv 12,30v
Ohm test Valve Iacv-13,4 ohm
ECT-5v
TPS-4,8v
Today I cleaned the IACV and it does the same as before. When I drive and I want to accelerate the car goes disscontinued .Even if I remove the IACV jake ,the car works jerky (when I push the throttle constant at 1500 rpm the car works the same as in the video that I showed you.If I want to keep speed between 1500 and 2500 rpm the speeds suddenly jumps over 2500 rpm).
-Battery 12,30v
-Iacv 12,30v
ECT-5v
TPS-4,8v
Contact ON
-Battery 12,30v
-Iacv 12,30v
ECT-5v
TPS-4,8v
Today I cleaned the FITV and it does the same as before. When I drive and I want to accelerate the car goes disscontinued .Even if I remove the FITV jake ,the car works jerky (when I push the throttle constant at 1500 rpm the car works the same as in the video that I showed you.If I want to keep speed between 1500 and 2500 rpm the speeds suddenly jumps over 2500 rpm).
-Battery 12,30v
-Iacv 12,30v
ECT-5v
TPS-4,8v
https://www.youtube.com/watch?v=QFk-...ature=youtu.be
today I shoot more detail what the problem has my car. Please watch and help me!thank you
yoffer
May 31, 2007 11:54 AM
CivicHP
15
Nov 29, 2005 07:31 AM
