95 civic dx/d16y8 swap/P28 ECU - VTEC solenoid oil leak
Old 11-16-2014, 05:52 AM
Tyler Bunger's Avatar
Default 95 civic dx/d16y8 swap/P28 ECU - VTEC solenoid oil leak
help! i got a 95 civic dx with a swapped d16 vtec. vtec is not hooked up i plan on getting the plug and pins and a p28 ecu. my problem is i have a leaking vtec solenoid? and ive replaced the gasket and the solenoid itself still leaks. so i plan on replacing the head with a d16z6 head thats where i need some information. any help is appreciated!
Old 11-16-2014, 05:55 AM
Former User's Avatar
Default re: 95 civic dx/d16y8 swap/P28 ECU - VTEC solenoid oil leak
What head is currently installed?
What information do you need?
Old 11-16-2014, 05:59 AM
d16 y8 head and block....ive read that you have to use the z6 dizzy on the z6 head or can i use the y8 dizzy
Old 11-16-2014, 06:08 AM
Default Re: 95 civic dx/d16y8 swap/P28 ECU - VTEC solenoid oil leak
You can probably fix the VTEC solenoid oil leak if you HondaBond seal both gaskets - that's what I did.
And I don't believe you need to swap to a Z6 head and distributor. The P28 ECU will run the Y8 engine, but you may or may not need to get a Y8 basemap chip. The swap gurus should be able to answer this question.
Old 11-16-2014, 06:17 AM
oh ive tried just about everything havent tried hondabond but i eventually want vtec to work so i was just gonna replace the head and solve that problem all together and then i found a z6 vtec head for 70$ that i dont have yet but was planning on buying
Old 11-16-2014, 06:23 AM
Why do you think that you won't be able to make VTEC work for the Y8 engine?
Old 11-16-2014, 06:28 AM
doesnt it run off oil preasure? and wouldnt leaking make it lose preasure or something?
Old 11-16-2014, 06:30 AM
What's easier - fixing the VTEC solenoid oil leak with HondaBond or replacing the head?
Old 11-16-2014, 06:32 AM
i see what your saying prolly fixing it with the hondabond but i read that the z6 head is better so i just figured why not?
Old 11-16-2014, 06:35 AM
...i read that the z6 head is better so i just figured why not?
I don't remember reading this^. Links? Maybe somebody else can answer this question. My guess is that if there's any difference, it's minimal or insignificant.
Old 11-16-2014, 06:42 AM
i think i might have read it wrong i read that the z6 has better high end and the y8 has better low end but i might just buy another y8 head or try replacing the gaskets again and try the hondabond
Old 11-16-2014, 10:41 AM
92ehatch's Avatar
i dont think there is enough of a difference between the y8 and z6 thats worth doing all that.
supposedly the factory intake is better on the y8 and the factory header is better on the y8
supposedly the z6 head flows better than the y8 ive heard that as well.
but in the end you will be disappointed in the work required to change to a z6 head for something so minimal.
Old 11-18-2014, 07:35 AM
oh ok thanks man i think i need new piston rings as well because its got some low end torque but when im at a higher rpm you can smell the oil burning and it sounds like its struggling or something i know its got a lot of miles on it but maybe when i get vtec hook up it will run better
ClutchPapi
06-04-2013 07:13 AM
Matt McCabe
11-26-2012 11:51 AM
bklounge30
07-19-2011 05:43 PM
rpmraper
10
06-12-2011 08:25 AM
mikej94civex
05-03-2010 11:52 AM
Quick Reply: 95 civic dx/d16y8 swap/P28 ECU - VTEC solenoid oil leak
