94 civic sedan window switch problem
Old Nov 9, 2014 | 07:19 PM
raverx3m's Avatar
Default 94 civic sedan window switch problem
pass side switch works.
all other windows work
driver side window control only works down.
is this a common problem?
the switch is clean and good I took it apar and cleaned it.
besides the switch what else can it be
just want some qick opinions on what to check
Old Nov 9, 2014 | 07:28 PM
Former User's Avatar
Default Re: 94 civic sedan window switch problem
It almost must be the master switch.
Old Nov 13, 2014 | 10:13 AM
supak111's Avatar
Yea its the switch like RONJ@HT said. Electrical contacts inside the switch on the UP side are damage/dirty/too far and its not making a good connection, something could be broken inside the switch too tho. if you are handy you might be able to take the switch apart and fix it but these are cheap on eBay and junkyards..
Old Nov 13, 2014 | 01:35 PM
raverx3m's Avatar
the pass switch was not working also
I took both apart and cleaned it. I do it all the time on most cars.
now pass switch works
and driver still don't work
all contacts are clean
I just didn't want to dig in too deep in the circuit if thers a common problem with these that I can just go straight to and fix it.
door locks also don't work and dash lights( which I kinda have an idea why)
Old Nov 14, 2014 | 08:52 AM
There's really no need to guess. Continuity testing of the driver's master switch is pretty simple.
xfiles
Nov 20, 2014 05:27 AM
dirtridernathan
12
Jun 29, 2013 10:32 AM
BlueIntegraBoy
Apr 14, 2008 10:23 PM
ExiledinIN
Apr 19, 2005 05:52 PM
andrekun
Apr 15, 2002 02:24 AM
