alternator fuse problem
Old Nov 9, 2014 | 03:33 PM
mugen94's Avatar
Default alternator fuse problem
hey guys, I run a H22a in a civic EK. I installed a new alternator a couple weeks ago, since then no problem. but yesterday my speedometer stop working, and I know alternator and speed sensor is on the same 7.5 fuse. it was blown.. I replace it and instantly it blow again.
replace it again and unplug the connector at the alternator and start the engine. the fuse did not blown. but as soon as I replug the alternator connector, it blown right away.
did some one ever had the same issue ?
Old Nov 9, 2014 | 07:41 PM
holmesnmanny's Avatar
Sounds like a wire came loose off of a plug or connector and now is touching metal. You should look around for a broken wire.
Does it only blow with the key on ?
Old Nov 10, 2014 | 01:53 PM
mugen94's Avatar
Default Re: alternator fuse problem
yeah it blow only with the key on and with the connector pluged to the alternator
Old Nov 10, 2014 | 07:38 PM
Sounds like the alt is just bad. Swap it out under warranty.
Where did you get it from ?
Old Nov 12, 2014 | 04:58 PM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ replace the alt. 94
nolimitlowrider
Mar 16, 2019 06:49 PM
mugen94
Nov 9, 2014 03:56 PM
DVPDC2
Jul 29, 2008 02:34 PM
4thgenx42
Aug 19, 2006 06:47 PM
