01 accord rev issues
hi i just swapped an engine and auto tranny in my brother inlaws car. car starts fine but when u hit the throttle it dies. you can get it to rev up if u feather the throttle really fast. acts like the fuel is shut off when it dies. any info would be greatly appreciated.
Two most common issues that happen during a swap that leave you with the issues you are describing. The MAP and TPS connectors are switched - what are the wire colors you have plugged into the MAP sensor?
Next, G101 on the drivers end of the plenum is left off or loose.
99turboaccord
Mar 1, 2019 08:46 AM
