95 civic dx with D15b7 - need help with d16z6 swap
Hey guys I have a 1995 Honda civic dx coupe there is a d15b7 motor in it! It's stick shift I want to swap it with a d16z6 motor but idk if it sits right in and plugs the same what changes do I have to make help me out Im lost my first car my first swap
And you haven't even made an effort to search, or read. You just come to us, palms out...and ya know what? You'll get the same answer everyone else does.
Go read the FAQ sticky.
Wire up VTEC solenoid and pressure switch to the P28 ECU. Swap timing belt mount from the B7 over to the Z6.Reuse everything else from the B7, axles, wiring harness,mounts.
https://honda-tech.com/honda-civic-d...tions-1998336/
Read that. If you still haven't found the answer to your question, then you need to go back to elementary school - the answer is there. You could also click this link, where your question is answered "About 34,800" times.
To be completely blunt, if you can't figure out this very basic stuff, swapping an engine is probably a bit above your competency level.
Okay I think u guess understood me wrong I want to swap the whole motor out not a mini swap so I'm asking what do I need for that does everything plug in where the old motor was plug in??
EDIT: You will also need the Z6 distributor or equivalent.
He's no troll. The issue is that he hasn't read Hero's post and hasn't visited the FAQs sticky as instructed. There's not much to discuss here until the OP puts in some effort.
It's always interesting learning the culture of a new (to me) forum.
My model specific motorcycle forum specializes in tormenting sellers if they even mention an item anywhere other than classifieds.
gmclb7
Dec 11, 2012 05:43 AM
JDMhoe1992
Nov 15, 2011 04:18 PM
