97 Civic Ex manual transmission - Hard to move shifter
Old Nov 5, 2014 | 12:33 PM
gillman331's Avatar
Default 97 Civic Ex manual transmission - Hard to move shifter
I drive a 1997 Honda Civic Ex with a manual transmission. The other day my resonator came off, so until the part gets here I'm driving with no exhaust from the resonator back. The problem is that all of a sudden the shifter is really hard to move. It still moves and goes in gear and the car drives fine by it takes a lot more than normal force to move it (normal it slides like butter). I'm wondering if anyone has an idea of what it is? Maybe the sound vibrations broke/moved something. Any insight would be a huge help!
Old Nov 5, 2014 | 12:48 PM
ejv8s10's Avatar
Default re: 97 Civic Ex manual transmission - Hard to move shifter
Get under the car and check these 2 ideas:
Did the exhaust coming off hit (and damage) the shift linkage?
Is exhaust heat being directed onto the shift linkage?
Old Nov 5, 2014 | 01:27 PM
09chaplak's Avatar
Loves Tossing Salad
yaaaaaaaaaaa damage to the linkage might have caused it to bend or otherwise move it in a different position making it harder to shift. Or perhaps it's catching on the flange from the cat and that's the resistance you're feeling. Heat will cause the bushings to become mushy and stick, possibly making it harder to shift.
Old Nov 5, 2014 | 02:52 PM
gillman331's Avatar
Alright I'll definitely check that. Its hard to move side to side also that could also be the shift linkage too right?
Old Nov 5, 2014 | 03:44 PM
Former User's Avatar
Originally Posted by ejv8s10
Get under the car
Old Nov 6, 2014 | 07:31 AM
gillman331's Avatar
I just noticed that when I go over bumps (and hit the gas in too high of gear) there is a clink/clunk noise from like right under the center console. Is that just more clues that it might be the shift linkage?
Old Nov 6, 2014 | 07:33 AM
Crawl under the car and inspect. Post pictures.
Old Nov 6, 2014 | 07:49 AM
09chaplak's Avatar
Loves Tossing Salad
dude you better crawl under the car before you post another thread.
alvinoolivas
Jun 25, 2011 09:06 AM
Hunterflo
Honda Civic (2001 - 2005)
11
Jun 30, 2010 01:16 PM
HatchSpeeD
15
Apr 6, 2008 08:37 PM
zoso
Aug 30, 2007 08:27 AM
loclowd
Oct 10, 2005 12:11 PM
