99 civic creaking / grinding sound bumps
Old Nov 3, 2014 | 03:19 PM
ashtonallen's Avatar
Default 99 civic creaking / grinding sound bumps
i have a 99 civic that makes a creaking or grinding sound when i go over bumps. i have noticed that it's much worse going over bumps when i also making a left turn. oddly, it doesn't do the same thing going over bumps and a making right turns. any help diagnosing would be appreciated.
Old Nov 3, 2014 | 03:27 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 99 civic creaking / grinding sound bumps
Sounds like an issue with your bushings, specifically on the left side. Is the noise coming from the front, or the rear?
Old Nov 3, 2014 | 03:31 PM
i'm pretty sure it's coming from the rear passengers side. it's gets much louder with more weight in the car - if that is helpful.
Old Nov 3, 2014 | 03:43 PM
NotARaCist's Avatar
Inspect your bushings and ball joints, starting with that wheel. If it's rubber, it might be the source. Pretty common for cars this age.
Old Nov 3, 2014 | 04:22 PM
thank you for the help
Old Nov 4, 2014 | 05:56 AM
tony_2018's Avatar
Fish Twig
Definitely bushings, take a look a the trailing arm bushing.
Old Nov 4, 2014 | 12:56 PM
Former User's Avatar
Also check the exhaust system.
Old Nov 6, 2014 | 04:36 PM
i'm a little embarrased to say i can find the ball joints in the rear. can you suggest where i can find a diagram?
redm3turbo
12
Jun 11, 2011 04:35 AM
bunks99si
Mar 7, 2006 07:29 PM
jdmztrane
Jan 21, 2006 08:08 AM
sil
Nov 24, 2003 04:52 AM
