can't get topside of caliper to reach where it bolts back in
Old Nov 2, 2014 | 03:11 PM
ShadowDaisy82's Avatar
Default can't get topside of caliper to reach where it bolts back in
Hi I have a 98 honda civic ex automatic. After attempting to have my front brake pads changed, we can't get the top side of the caliper to reach where the bolt goes in to tighten it. The caliper fits over the new pads and the bottom of the caliper is able to be bolted back on fine but the top is like a half inch to short of reaching. Any thoughts? Advice? Would be helpful
Old Nov 2, 2014 | 03:33 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: can't get topside of caliper to reach where it bolts back in
Either you're pinching something, your slider pins aren't properly pushed in, or you didn't compress your caliper piston enough.
Old Nov 2, 2014 | 03:37 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Something may not be aligned. Remove the lower caliper bolt and pull the caliper back off. Then push the slide pins in and then try to reinstall the caliper. Once the holes line up, then install the bolts.
Old Nov 2, 2014 | 03:47 PM
Former User's Avatar
Clear pictures would surely help here.
Old Nov 2, 2014 | 05:42 PM
Problem solved- the caliper pin had something preventing it from going all the way in. Took it out sprayed it down and sprayed the pin hole and it went right in.
RIMPR
Honda Civic (2006 - 2015)
May 23, 2015 06:05 PM
standbackimapro
Honda Civic (2001 - 2005)
Aug 10, 2006 04:29 PM
Carlo
11
Nov 18, 2003 01:21 PM
lePetitePrince
Oct 19, 2003 12:10 PM
CKS
Aug 20, 2001 09:39 AM
