Good Aftermartket Crankshaft Pulley/Harmonic Balancer?
Old Nov 2, 2014 | 03:15 AM
__oversea's Avatar
Default Good Aftermartket Crankshaft Pulley/Harmonic Balancer?
I noticed slight wobble and noise during idle on 2000 Accord 4cyl.
I torqued bolt down to see if bolt was being loose, but it wasn't.
Anyone have good experience with aftermarket pulley or should I get new from Honda (not sure how much with employee discount).
Old Nov 2, 2014 | 09:28 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Good Aftermartket Crankshaft Pulley/Harmonic Balancer?
Stick with OEM.
Old Nov 2, 2014 | 12:22 PM
holmesnmanny's Avatar
^^ this .. Harmonic Dampeners are extremely important to longevity of the motor .. i would stick with oem
Old Nov 23, 2014 | 09:57 PM
__oversea's Avatar
Okay, I replaced with OE crankshaft pulley. but it still have slight wobble to it, better than before but still there (noise is gone too). is crank shaft itself is bad?
note: torqued down to 181ft lbs.
Old Nov 23, 2014 | 10:25 PM
Did you buy a new key for the crank ?
Old Nov 23, 2014 | 11:17 PM
__oversea's Avatar
no
it looked fine (no deform or play).
I hope nothing wrong with crank shaft, it's not worth fixing it then.
Old Nov 24, 2014 | 03:32 PM
__oversea's Avatar
also wobble is side to side (only at idle), no up and down play.
I may try to replace key also, since it's under $10.
Old Nov 24, 2014 | 06:34 PM
accordturb96's Avatar
some if it may be due to machining, is the wobble the exact same as before?
Old Nov 24, 2014 | 08:02 PM
__oversea's Avatar
Originally Posted by accordturb96
some if it may be due to machinging, is the wobble the exact same as before?
no.
less side to side wobble, also weird noise is gone during idle too.
I am gonna take it apart and inspect the key closely.
Old Nov 24, 2014 | 08:08 PM
Originally Posted by __oversea
no.
Well you're heading in the right direction. Make sure your timing belt pulley behind the harmonic is on correctly and not having issues either
NickGREPSMN
Apr 29, 2013 08:54 AM
mejim707
Jul 5, 2009 01:36 PM
Elevorett
Jul 21, 2007 09:32 AM
hondaZvic
Sep 24, 2004 04:33 PM
jetpilot
May 24, 2004 05:50 AM
