Civic Type R (EK9) Base Map (B16B)
Hey guys
i hope im in the right topic, im searching for a b16b base map...
its about swapping a b16b into a CRX thats y i need a base map..
i appreciate any help guys thanks in advance
i will run a p28 , obd1
later i will fine tune it but at first i want to test drive and all of that i wanna go sure i run the right map so i wanted a b16b (ek9) base map. so nothing can go wrong
thanks for the help so far
i searched for the names and i was searching in their shops but im not sure what exactly i should get.... i searched the whole stores and i found nothing about a B16B basemap....
what am i doing wrong? i dont know well about ECU and stuff and my english also sucks sorry, i appreciate your help
EDIT: these are the links im stuck
http://www.phearable.net/tuning-software-en/
http://www.xenocron.com/basemaps-c-23_54.html
Try here:
Ecu Chipping Hardware - Phearable.net - Categories
If your ecu is already chipped, you only need the first option. If it's not already chipped, you need to spend the extra $2.00 and get the socketing kit with it.
Also, i believe that John (Phearable) will include a customized basemap if you purchase a NepTune or Hondata setup from him, but don't quote me on that. If I'm incorrect here, I'm sure he'll chime in and clear that up.
If you just go ahead and get one of those systems right away, it's money that you don't need to spend twice.
thanks mate
i have a stock p28 right now but friends will socket it...
well i will use the p28 so i just need this one:
Phearable.net Custom OBD1 28 Pin Eprom Chip Basemap
haha no its okay thanks i wont do that..
the thing is i have a 2 Gen CRX and a B16B (EK9 typer) will be swapped into it and i just want a base map (ek9 stock map) to do some test driving and driving home before someone will fine tune it / map it..
the base map i get now must not be something special... i just dont want to run any map and my engine blows up when im driving....
i hope you know what i mean sorry my english is really bad but i hope u understand what i want...
youngboiCD7
Engine Management and Tuning
Apr 12, 2018 06:13 AM
Txdragon
Mar 8, 2017 05:57 PM
