Dpfi T/B coolant bypasss
Hello Honda people!!! I need help with a clear write up with (pics if available) of the process of bypassing the throttle body coolant. I need my air to not be heated up by coolant. Trying to eek as much power as I can from it. Thanks in advance.
If you cant figure out how to disconnect two hoses from the TB and connect them together, I dont think you need to be trying to eek any performance out of anything...
And even if you could do that, there would be NO change in power output. You would be MUCH better off just doing a full tune up: plugs, wires, cap, rotor, air filter. That WILL give you back a few lost ponies, AND will give you a smoother running engine.
All you need is an appropriately sized barb to barb fitting, which you should be able to pick up at Home Depot or the like. But like he said, it's an absolutely pointless "mod".
AtoZ
Jan 17, 2009 11:33 AM
kaluwa3
Sep 4, 2007 09:47 AM
WickidSi
Apr 8, 2003 06:17 AM
