HELP atmospheric pressure sensor
Old Nov 1, 2002 | 03:16 PM
See Are X's Avatar
Default HELP atmospheric pressure sensor
I have a code 7, its the atmospheric pressure sensor. My setup is a 92 B18A in a 91 Crx SI(everything converted to non-obd). My question is, will this affect my mileage??? It might just be me, but it seems like my car is killing a lot of gas.
Also, I need to know where the red/wht wire goes, to what pin location on the ECU. I know the grn/wht goes to C12 and yel/wht goes to C13.
Old Nov 2, 2002 | 08:14 AM
Kataku2K3's Avatar
Default Re: HELP atmospheric pressure sensor (See Are X)
How did you get these extra wires???? You shouldn't have had to mess with the interior wiring harness that much, i don't think. If you got an Si you already had DPI and all ur distributor sensors wired. Oh, well we'll see. I'm pretty sure pin C12 is the second sensor ground (SG2) so basically it just grounds off a few of the main sensors. I really don't know how good ur car is running if you don't have C13 going anywhere because i know that that is TPS voltage+ (VCC2). Check these, and then let us know what is going on more. Laterz
ZCHondaCRX91
Engine Management and Tuning
Dec 29, 2011 01:48 PM
mainevnt
Apr 24, 2008 04:33 PM
NazVil86
Apr 11, 2006 11:01 PM
Ls InTeGrA RaCeR
Oct 31, 2005 10:23 AM
sieger
Sep 6, 2002 10:33 AM
