Ignition Coil Test results question
Old Oct 25, 2014 | 10:55 AM
mtdineen's Avatar
Default Ignition Coil Test results question
2000 CRV with B20Z2 at 137,700 mi. Tested the igntion coil (part of a rough idle and timing issue diagnosis). Primary winding showing fluctation between 0.9-1.3 ohms (64° air temp). Manual I have says replace if not between 0.63-0.77 ohms (@ 68°). What say you folks?
BTW, Secondary winding ok @ 15.6 K ohms (spec 12.8-19.2).
Old Oct 25, 2014 | 10:58 AM
Pullig's Avatar
Default Re: Ignition Coil Test results question
What issues are you having? I remmeber checking mine as you have and the specs were slightly off as well. With the secondary in spec. Mine runs flawless Maybe try another test at the 68 degrees?
Old Oct 25, 2014 | 07:06 PM
holmesnmanny's Avatar
U have to subtract the internal resistance for the primary test. Touch the leads together and it should be .01
Your results look fine.
Old Oct 25, 2014 | 10:20 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Ohm testing a coil is about as useful as kicking the tires. If the coil ohms out bad,its bad.If it ohms out good,it could still be bad.
On a modern vehicle such as yours a scan tool is the only sure fire way to a quick and accurate diagnosis.
Otherwise you could be testing sensors up the wazoo looking for a fault....
Old Oct 27, 2014 | 09:16 AM
mtdineen's Avatar
Yeah, the coil is fine. Ohms testing with a MM is only good in some situations. Thanks folks!
nickelz34
Jan 2, 2013 04:42 AM
Lasky
Jan 31, 2011 04:50 AM
hfrex
Jan 8, 2009 02:43 PM
aalb1
Aug 7, 2005 10:50 PM
