Can springs be upside down?
Old Nov 1, 2002 | 02:06 PM
Aron Parsons's Avatar
Default Can springs be upside down?
Sorry for such a question, but i was notcing today that my front springs are on upside down (or so it appears). all the labeling is upside down on them, as opposed to the rear where the labeling is all right side up. does it matter which way they are installed? i haven't had any problems (yet), i'm just double checking. thanks.
Old Nov 1, 2002 | 02:29 PM
flip b18b's Avatar
Default Re: Can springs be upside down? (OvERaCiD)
i would think that you should flip them over
Old Nov 1, 2002 | 02:52 PM
performula's Avatar
Are they coilovers or lowering springs?
If they are lowering springs you have to reverse them. If they are coilovers, you're OK, because they are the same throughout and flat on the upper and lower part of the coil.
[Modified by performula, 11:52 PM 11/1/2002]
Old Nov 1, 2002 | 07:39 PM
IN VTEC's Avatar
If you have coil springs, then yes it does matter.
The springs have a flat seat on top and an offset seat on the bottom. If you put them in upside down, the spring will be crooked. I don't even know how you would get them to properly line up with the spring hat if they were upside down....it's pretty hard for that to happen.
ej8ray
Suspension & Brakes
May 28, 2011 09:09 AM
JPerkMr954
Suspension & Brakes
Jan 18, 2011 01:10 PM
CLIPHSET
Suspension & Brakes
Sep 9, 2009 01:58 PM
Paluce
Suspension & Brakes
Dec 8, 2008 08:59 AM
wu tang
Jul 17, 2002 06:22 AM
