2000 civic fuel pressure spark lot of compression
Old Oct 19, 2014 | 08:59 PM
sh!ft's Avatar
Who the fack changed my title?!
Default 2000 civic fuel pressure spark lot of compression
2000 ek civic with built gsr, obd1 ecu, won't start. It cranks and fires when brake cleaner/gas is sprayed into intake. When it does turn on, it idles good for a few secs and dies. Code 4 is thrown.
Spent 4 hours checking the car over and am stumped.
Any input?
Old Oct 20, 2014 | 02:03 AM
EsotericImage's Avatar
Retired Moderator
Default Re: 2000 civic fuel pressure spark lot of compression
you need 3 things
air
fuel
spark
fiigure out which one isnt working then get back to us
Old Oct 20, 2014 | 02:21 AM
HondaPartsHero's Avatar
Technical Hero
Here's diagnosis for code 4
I'd honestly try a good known working ECU if the one you have has been chipped as well even if its not one for the engine.
Old Oct 20, 2014 | 08:20 AM
sh!ft's Avatar
I drove my car up there, used my obd1 distributor pinned from obd1 to obd2, used a hondata, along with a computer to read the codes on a gsr base map, still did the same thing.
Some one said it could possibly be the dash harness??
carlos_D
Oct 28, 2018 05:20 PM
Biggem Clark
Sep 18, 2016 07:11 AM
Archidictus
31
Dec 29, 2005 03:28 PM
jeiden
Jan 10, 2004 06:29 PM
91civicEX
15
Sep 3, 2003 10:33 PM
