Diagnostic issue: 1998 Civic with B16a2 not comunicating with ECU
Old 10-22-2018, 07:51 AM
carlos_D's Avatar
Default Diagnostic issue: 1998 Civic with B16a2 not comunicating with ECU
I have a 1998 civic CX hatchback,With a turboed B16a2 Running chipped Obd1 ECU with Hondata s300( Phearable.net). Car ha new 440CC injectors, Distributor, Starter,plugs,wires, engine harness (chandler Autosports) harness was converted to obd2 to obd1. everything was working great one day I pulled car out to vacuum carpet. when I was done I went to start and put back in garage. and it would just turn over. checked for spark has good spark, checked for fuel getting fuel. checked ECU getting power to ECU. cleaned all grounds car will not start. checked main relay as well. I can hear new walbro fuel pump prime. I did notice that when I turn key to on position the CEL does not come on. ive tried to look up why it wouldn't come on cant find anything. any help would help
I also checked the clutch switch under clutch pedal and tried using jumper still car would not start. I plugged laptop into ECU and pulled up hondata it gets readings from Map Sensor and RPMS do show up when I turn motor over.
Old 10-22-2018, 09:41 AM
Hysterically Calm
TomCat39's Avatar
Default re: Diagnostic issue: 1998 Civic with B16a2 not comunicating with ECU
Did you test for injector pulse with a noid light?
Old 10-22-2018, 10:10 AM
carlos_D's Avatar
yes I checked for that. one of first things I checked after I checked for spark.
Old 10-24-2018, 10:08 AM
carlos_D's Avatar
Default Re: update:1998 Civic with B16a2 not comunicating with ECU
So I have gotten CEL to come back on. it seems like cab harness was cut way before I bought car back in 07. They soldered some the harness wires back to plug but not some. The engine harness that connects to the cab harness that connects to ECU. Ground wire going in for ECU was not soldered just twisted with a rubber sheathing over it I'm guessing over time it just fell apart. did not have time to try and start was on lunch break. I will re solder cover with rubberized sheathing and try and start.
Old 10-25-2018, 04:28 AM
carlos_D's Avatar
Well fixed CEL issue but car still cranks but does not start.
Old 10-26-2018, 04:08 PM
carlos_D's Avatar
Default Re: Diagnostic issue: 1998 Civic with B16a2 not comunicating with ECU
FIXED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 10-28-2018, 05:20 PM
Moderator
TheShodan's Avatar
please do the right thing and describe to us in detail what you did to actually solve the issue, so others can benefit.
domestic_rice
12-19-2012 10:43 PM
Nick7
05-14-2011 08:57 AM
silentbeatz
12-16-2008 09:44 AM
Destructive-
08-12-2008 09:25 PM
91civicEX
12-12-2003 11:44 AM
Quick Reply: Diagnostic issue: 1998 Civic with B16a2 not comunicating with ECU
