92 Honda Accord ECT Sensor wires cut!!
Old Oct 17, 2014 | 01:01 PM
JJMarley's Avatar
Default 92 Honda Accord ECT Sensor wires cut!!
Right at the meeting point of the wire going into the connector. The wire has been ripped from there causing me to get a CEL. Is there any way i can fix it without replacing it? I would love to post a picture of it but im illiterate on how that works from a phone. Please! Any help is appreciated. TIA!!
Old Oct 17, 2014 | 03:56 PM
lazlong's Avatar
Default Re: 92 Honda Accord ECT Sensor wires cut!!
You could re-pin it but, you need a pin tool and crimpers as well as the knowledge on how to use them.
Go to the pick-your-own salvage yard and cut the connector off. Give yourself plenty of wire to work with (at least 6 inches). Carefully cut the casing off the wire harness then solder and heat shrink wire to matching wire color. Re-wrap the harness and reconnect the connector to the ECT.
Old Oct 18, 2014 | 11:40 PM
NerfGunner420's Avatar
junkyard. cut the pigtail off with extra length or wire and solder it in with heatshrink!! easy as that
Old Oct 20, 2014 | 10:45 PM
slowcivic2k's Avatar
Old Oct 22, 2014 | 07:49 AM
Duwyenie's Avatar
U need hlp I ran out of gas put sum in it started jst fine then tried to go sum place later..wouldn't start Iddidn't hear any noise frm da fuel pump so I replaced dat..still won't start & still I dnt hear da fuel pump..ppl keep sayn its the ecu? Where is dat located? Plzzz hlp
Old Oct 22, 2014 | 07:50 AM
Duwyenie's Avatar
My car is a 90 Honda accord lx
Old Oct 22, 2014 | 11:23 AM
main relay
Old Oct 25, 2014 | 10:34 AM
JJMarley's Avatar
I have it fixed. Thanks everyone. I did end up going to get a few from the pick and pull. Ended up getting it for free. Twisted wires together. No hard start, no mpg drop, and NO CEL!! Mecahnic wanted to charge me $180. I fixed it for free. Wooo! Dodged that bullet. THANK YOU!
G2_Fella
Oct 11, 2008 08:21 PM
riceburner700
Apr 8, 2007 08:07 AM
YoungKadafi
Mar 21, 2007 08:12 AM
streetstylenperformance
Feb 26, 2004 03:28 PM
