97 civic ex b18c tps issues....
Old Oct 16, 2014 | 05:21 PM
Thor294's Avatar
Default 97 civic ex b18c tps issues....
To start its got a obd1 phearable tuned p28-a02 ecu....
Key ON engine OFF... I back probe the red/black wire at the ECU before the conversion harness..... I get like .005v and wot is 3.37v... Why is that so low?
Lwhen the engine is running.... I get... -.09v and it goes up when revving....
The tps gets 5v at the plug.
I got a volt meter and back probes to use... Help me
Old Oct 16, 2014 | 05:26 PM
Thor294's Avatar
Default Re: 97 civic ex b18c tps issues....
New tps from auto zone btw.
What should the ohms be on the ground side of the tps to say the negative post?
Old Oct 16, 2014 | 05:28 PM
Former User's Avatar
What are you using as ground in your Red/Blk wire voltage test? Did you calibrate the TPS?
Old Oct 16, 2014 | 05:34 PM
Thor294's Avatar
Using either cigarette lighter or a bolt in the door. I get the same reading if I back probe the wire at the tps and use battery ground.
No did not calibrate tps... I'm a Honda newb. What's the procedure for that?.. Jk found it
https://honda-tech.com/honda-crx-ef-...hread-2830131/
Old Oct 16, 2014 | 05:37 PM
You need to calibrate it. Loosen the TPS screws and rotate the TPS until the Red/Blk wire reads 0.5V at closed throttle. Tighten the bolts. Test voltage at WOT. Voltage should be roughly 4.5V or a little higher.
Old Oct 16, 2014 | 06:52 PM
Thor294's Avatar
My hero.
Guy I bought it from has a 700+HP nonvtec integra ... but doesn't know that the TPS needs to be configured.....
Old Oct 16, 2014 | 11:37 PM
tony_2018's Avatar
Fish Twig
Well.............did you know it needed to be configured??
Old Oct 17, 2014 | 03:02 AM
Thor294's Avatar
No . Any other tps I've done is just plug and play!!! I haven't worked on a Honda yet!!! lol. I remember reading that tps thread I just didn't see that part
fear45
Jan 8, 2019 12:26 PM
NerfGunner420
Aug 1, 2014 05:13 PM
Powered by VTEC
Jan 30, 2008 10:06 AM
ferio 95
Dec 10, 2004 09:16 AM
