uca from rock auto?
Old Oct 13, 2014 | 05:16 PM
Ef4doorwagon's Avatar
Default uca from rock auto?
Im thinking of getting uca from rockauto, theyre 24.99 a piece with balljoint but i dont think it comes with bushing. The brand is UltraPower. Has anyone bought this uca?
I think oem is 70 plus tax, idk if it comes with balljoint or bushing.
Old Oct 13, 2014 | 05:23 PM
James89DX's Avatar
Default Re: uca from rock auto?
Get Moog if aftermarket. Last I checked, their Moog arms WITH ball joints on rock auto were fairly inexpensive. I try to use Moog on tie rod ends and ball joints on all of my cars when using aftermarket parts.
Old Oct 13, 2014 | 07:31 PM
40Each. Moog should be direct fit huh. Also, i have an 89 sedan, but all 88-91 should be the same with uca?
Old Oct 13, 2014 | 07:45 PM
James89DX's Avatar
I'm not sure if all 88-91 are the same on UCA's but I would suspect so. I have Moog UCA's (and everything else) on my 89 hatch
Old Oct 13, 2014 | 07:59 PM
I read somewhere that the 88-89 upperball jpints are welded onto the uca, and the 90-91 arent, idk if it applies to aftermarket tho.
Old Oct 13, 2014 | 09:58 PM
ef2_civic's Avatar
Welded or pressed in doesn't matter. I've had a 91 and currently a 89 sedan and parts like that inter changeable
Old Oct 14, 2014 | 11:16 AM
Tyson's Avatar
Yes that's true, but the exact years vary.
And it wouldn't matter for an aftermarket replacement unless you're just replacing the ball joint separately. Then obviously you need a non welded arm.
Old Oct 14, 2014 | 03:06 PM
M3THTICAL(EF)'s Avatar
I got the raybestos units from amazon paid like $70 buck for both of them. Pretty beefy compared to the shitty ebay adjustables the car came with.
sikciv666
Aug 10, 2007 04:43 PM
blang4d
Apr 17, 2007 10:50 AM
dat_flip
Nov 27, 2004 02:23 PM
allm0torGSR
12
May 10, 2004 07:54 PM
CunninLynguist
10
Feb 1, 2004 08:45 AM
