96 civic failed e-test 4 times and won't pass need help
Old Oct 13, 2014 | 12:51 PM
adzenry25's Avatar
Default 96 civic failed e-test 4 times and won't pass need help
Hey guys I have a 96 civic hatch here with a stock engine and I'm trying to put it under my name. It has failed etest about 4 times on high HC on idle. The lowest I got with it is 344 and the highest was around 417. I live in Canada so the limit is 200. Iv done everything I could think of to make it pass (new cat, set the valves, check timing, clean the injectors, new air\fuel filter, new plugs and wires, and maybe a little more to it) please help
Old Oct 13, 2014 | 01:13 PM
09chaplak's Avatar
Loves Tossing Salad
Default Re: 96 civic failed e-test 4 times and won't pass need help
Just did a quick search and found some good info, main causes being ignition timing, faulty ignition components, lean mixture blah blah. Any check engine codes? Probable culprit is the EVAP system.
Old Oct 13, 2014 | 01:33 PM
adzenry25's Avatar
There is no codes on it.
Old Oct 13, 2014 | 06:44 PM
Former User's Avatar
Does the CEL work?
Do a full ignition system tune up, adjust the ignition timing, and replace the thermostat if it's running cold.
Old Oct 14, 2014 | 04:56 PM
adzenry25's Avatar
ok thanks ill give it a try, iv already replaced the thermostat when i did the rad
wunfstgsr
12
Jul 7, 2016 06:43 PM
apaige58
10
Aug 5, 2013 04:36 PM
viet_sensationz
May 6, 2011 04:26 PM
dumkopf
Aug 29, 2007 05:51 AM
hybrid98
May 5, 2007 06:02 AM
