HELP!! engine boggles when i start up!!
Old Jun 27, 2007 | 11:08 AM
viet_sensationz's Avatar
Default HELP!! engine boggles when i start up!!
when i first start my engine at the beginning of the day it boggles and is idles really low like almost stalls then after it takes a bit to warm up itoks ok. but it boggles and shakes really bad until it;s wrmed up then it's ok . any inputs whats wrong!!?
Old Jun 27, 2007 | 12:36 PM
suspendedHatch's Avatar
Default Re: HELP!! engine boggles when i start up!! (viet_sensationz)
Boggles?
Clean out your IACV. Seafoam the motor. Check ignition timing. Check/clean/adjust your FITV.
This is assuming you keep up with all the other regular maintenance.
Don't ever say "boggles" again or I'll shoot you in the face.
Old May 6, 2011 | 04:26 PM
teggin94's Avatar
Originally Posted by suspendedHatch
Boggles?
Mine does the same cept it does it cold or warmed up between 800rpms-and 2k rpm then after 2k its got ***** to the wall ive got all new sensors plugs wires i seafomed it and checked the timing its to a T and advanced the igniton timing and still the same HELP!
riccyda27
Mar 16, 2009 10:53 AM
Spody02
12
Sep 9, 2008 10:16 AM
HSPxCARDO
Oct 23, 2007 10:10 AM
haophat
Aug 22, 2004 08:36 AM
them8te
May 5, 2003 08:08 AM
