91 STD civic jumping idle
Old Oct 12, 2014 | 06:38 PM
godofwar81's Avatar
Default 91 STD civic jumping idle
First off i took out my engine and swap for another same type. The old engine was running fine other then the rolling coal out the tail pipe. No cel just the smoking. So i found one from a junkyard which they cut the wire loom and engine mounts witch i knew they would. So i changed my harness and mounts and dropped it in and the cel was on got 4 codes, TP, IAC, IAT,16 fuel injector defective. So i knew that my other sensors where good on the other engine so i just changed my intake to the other engine. Then when i did that i got IAC,IAT codes only seems odd to me since they where fine on other engine. Car runs like crap idle up down with both of these not working and cant seem to find out why? Any help would be appreciated ty.
Old Oct 13, 2014 | 04:35 PM
godofwar81's Avatar
Default Re: 91 STD civic jumping idle
ok i just replaced the IAC,IAT with new parts and throwing the same codes. so i have to think its an electrical issue. does any one know if there is another sensor that can make these not read right?
Old Oct 13, 2014 | 05:13 PM
godofwar81's Avatar
ok i fixed it, the plugs for the IAC and IAT are the exact same. other then one is white and one is blue. i switched and blame fixed lol. and yes i hit my self with a tack hammer. but i blame honda for making these two plugs fit to different sensors!!!!!!
dh1212
Apr 2, 2016 04:08 AM
pfsmith99
Oct 7, 2012 02:40 PM
vvboy
Aug 26, 2010 01:06 PM
red_zx6_ninja
Apr 21, 2003 06:42 PM
PiYoImuT
Sep 7, 2001 09:08 AM
