Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
What parts do I need? Clutch and Timing Belt
Old Oct 12, 2014 | 10:42 AM
hometheaterman's Avatar
Default What parts do I need? Clutch and Timing Belt
I'm doing a clutch while doing a motor and am trying to put together a list of parts I need from Majestic Honda to order. This is for a 2006 Honda Accord EX V6 6-Speed.
I want to do the input bearing and throwout bearing as I believe one of the two is making noise and I can't find them listed on there. Does anyone know what Honda's actual name is for these or the part numbers? Also, besides that, the clutch disks, and the bolts is there anything else I need when doing the clutch?
For the timing belt, I'm getting a timing belt, adjuster, tensioner, the bolts and collars for the adjuster, the idler pulley and other two cam pulleys, and the upper and lower timing cover gaskets and then a water pump and water pump gasket. Is there anything else I need? Also, does anyone know where I can find the serpentine belt listed on majestics site? I can't find it anywhere on there.
One last question, is does anyone know where to find the rear main seal on their site? I'm not sure what category to look under. Are there any other seal to replace while swapping in the used motor?
Thanks guys.
live4soccer7
40
Sep 21, 2011 02:54 PM
540888
Apr 24, 2009 03:45 AM
VTecLude1994
Feb 23, 2006 02:59 PM
EF7
Aug 12, 2005 02:17 PM
TERRA
Jan 23, 2002 08:57 AM
