Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2006 civic si no crank no start
Old Oct 11, 2014 | 12:37 PM
sgtmajj's Avatar
Default 2006 civic si no crank no start
I have a 2006 civic si that will not crank or start. All that happens when I turn the key is the fuel pump relay clicks rapidly. Lights do not dim or go out. Where should I look for a problem?
Old Oct 13, 2014 | 03:32 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: 2006 civic si no crank no start
.....for real with this question?
Old Oct 15, 2014 | 04:09 PM
97emsedan's Avatar
Starter relay in the ECM maybe?
Old Oct 23, 2014 | 03:56 AM
sgtmajj's Avatar
97 that did not do the trick. still the same response. any other ideas or threads on here that may assist me?
Old Oct 24, 2014 | 02:47 AM
97emsedan's Avatar
Fuel, air, spark...
Cranks so we know that the possibility of spark is there, have you checked that your ignition system is good at all four cylinders? Pull a plug and have someone crank while you lol at the plug during cranking. There should be a good even spark sequence.
As well, you say the fuel pump clicks rapidly, does it pressurize the fuel rail? Can you check pressure at the rail?
Air shouldn't be a problem either. I trust the air filter is new?
Old Oct 24, 2014 | 06:52 AM
zangxuma's Avatar
I own a 92 Acura Vigor and a 2007 Honda Odyssey along with my 06 Civic. Contrary to the complaints that I have viewed here, our Civic has been a champion. The handling fits between my Vigor and Odyssey. It handles crisp like my Vigor without the stiff ride. It gets 40 mpg with the a/c on at 77 mph . I just replaced the rear brake pads at 74,000. It is only on its second set of tires. Knock on wood, I'll keep it as long as it continues to perform like it has.
Old Oct 26, 2014 | 11:41 AM
sgtmajj's Avatar
97 the fuel pump relay clicks rapidly. No it does not crank. I have traced the starting system up to the starter control relay. do you know exactly where this relay is located?
Old Oct 26, 2014 | 05:10 PM
97emsedan's Avatar
No, I do not. But I can look it up hopefully.
Old Oct 26, 2014 | 05:16 PM
97emsedan's Avatar
The relay is in a fuse panel located directly below the steering column.
Old Oct 26, 2014 | 05:20 PM
97emsedan's Avatar
It is the center one at the top, blue in color.
Old Oct 26, 2014 | 05:37 PM
97emsedan's Avatar
I got the info from Answers.com
Underlook
Apr 23, 2016 12:05 PM
olegles11
15
Feb 23, 2013 02:53 PM
WifesVTEC
Jan 31, 2011 04:46 PM
fcbdolphinz
Sep 8, 2009 03:54 PM
MrPotatoeHead
Nov 6, 2005 06:45 PM
