obd2 to obd1
Old Oct 10, 2014 | 11:18 PM
tablecivic's Avatar
Default obd2 to obd1
so it's inspection time for me, and my options are limited. i was wondering is there anyway to wire up the obd port to a step-down harness ? my vehicle is obd2a stepped down to obd1. curious if anyone every tried this ? or if it can be done? in my state the dmv plugs their computer in and checks for readiness and engine codes. i figure if you can wire up that port it would make life easier for us street cars to pass emissions.
Old Oct 11, 2014 | 04:40 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: obd2 to obd1
What engine and ECU are you using?
Old Oct 15, 2014 | 11:22 AM
94dxcoupe's Avatar
OBD1 ECU's will not display OBD2 readiness codes nor communicate via an OBD2 port. You are basically stuck with finding an OBD2 ECU that will run your engine well enough to smog.
Old Oct 28, 2014 | 02:12 PM
Gator417's Avatar
Can you not just plug the stock computer in for the duration of the test & put it back into fun mode afterwards?
Gator
Old Oct 30, 2014 | 01:08 PM
tablecivic's Avatar
i was just wondering if it could be or was ever done.
jrepko18
Engine Management and Tuning
20
Sep 26, 2014 06:45 PM
flash0124
Oct 19, 2012 08:32 PM
GS-Racer X
Jul 16, 2009 06:17 PM
Brugalontherocks
Apr 28, 2008 08:10 PM
