Need input on d15b
Old Oct 7, 2014 | 07:21 PM
Ef4doorwagon's Avatar
Default Need input on d15b
Bought a d15b block the other day. Its the jdm version of a d15b7, which is pretty much a d15b2 (pm3 pistons). The block was supposeably rebuilt with new bearings and piston rings, but the old pistons were re used. As I'm cranking it with a ratchet, it takes a bit of force, but it rotates fully.
I have my d15b2 block out of my car and when I crank it, it spins freely without any effort at all!
These are both blocks without heads. I can see like black carbon on the sides of the pistons, I don't think the shop cleaned the pistons thoroughly and I feel like maybe there's carbon buildup that's not letting it turn as easily? I'd like to know If that will mess up anything.
Old Oct 8, 2014 | 09:13 AM
jlicrx's Avatar
Default Re: Need input on d15b
an engine with the block honed and new rings installed is going to turn over harder than one that is worn out - won't spin freely
Old Oct 8, 2014 | 09:21 AM
Freemananana's Avatar
I agree with jlicrx. Also, do you have the spark plugs removed? I wouldn't worry about it too much.
Old Oct 8, 2014 | 09:35 AM
jlicrx's Avatar
I believe he stated these were both just blocks without heads
Old Oct 9, 2014 | 02:58 PM
Oh ok so its normal then. Good to know. Thx
Old Oct 10, 2014 | 03:01 AM
Oh, I didn't realize they were just blocks. I read block, but I was still thinking the head was attached.
If you have the head removed, you should be able to see the cylinder walls. I've seen carbon build up on cylinder walls from sitting for years and years. You'd probably be able to notice anything that is impeding the rotation.
91ls-v
May 25, 2005 08:03 AM
Tropicana18T
Feb 23, 2004 03:40 PM
Robban26
15
Jan 24, 2004 01:31 AM
KC GSR
Jun 20, 2002 08:47 AM
TurboR
May 17, 2002 04:59 AM
