D16y7 to d16y5 swap
ok. I have a 1996 Honda Civic dx had a d16y7 with a manual. The motor came out of a 1999 civic hx with the auto. I used the complete harness and axles along with the whole complete engine and Ecu and gauge cluster. Before I swapped motors the gauge cluster worked fine. Now the tach and speedo don't work. And even before I did the swap had an idle surge problem I couldn't figure out. And don't exactly have 175 to spend on a new iacv. Any idea or tips to try. Oh and the fuel pump stays running with ignition on and check engine light stays on. The idle surge don't start until the srs light goes off. And ideas at all to try is greatly appreciated.
You need a manual Ecu for that swap. And you'll also have to wire in the 5 wire oxygen sensor. I'm guessing your check engine light is on? If so post the codes.
I got the ecu wiring an everything out of the hx. I'm getting a tach signal from the dizzy. tried a different cluster. And just went to pull codes I notice no connection detected. When I changed engine harness is there some pins in supposed to change around or something? Between the green plugs by the ecu?
So let me get this right, you swapped an 99 auto hx into your 96 dx? All wiring were replaced in the 96? What wires were replaced and what ecu are you currently using in the 96 dx?
well I ended up frying the ECU. so I got a wiring harness and ecu for an HX manual.but now having a hard time figuring how to rewire the primary o2 sensor and the egr valve. trying to search for the wiring info needed but cant find anything.
egvtec
10
Nov 26, 2008 03:12 PM
ej2 coupe
Nov 22, 2007 05:43 PM
dapump2003
Mar 14, 2007 01:01 PM
