1992 Honda Accord f22 to f20b DOHC swap build/Help???
Old Oct 5, 2014 | 07:23 PM
Datechmaster's Avatar
Icon4 1992 Honda Accord f22 +future swap build
Hi everyone this is my first post as a member on the forum. Got shunned on some other car forums so now I'm here. This is my current project/build.
Anyway I need help with information on swapping the f22 to f20b dohc (Might change what engine later I haven't completely decided):
What upgrades, not too expensive, that I could do to the engine before installing it?
And are their any suggestions for the build (Besides saying I should do an h22...)
Thanks!!
Things I've already done:
-Replaced master relay (So that it would run consistently)
-New sway bar bushings
-205/45/R17 tires
-17" Focus rims
-Anthracite PlastiDip job
-Passenger side race seat done, driver side left
-Under dash LED glow multicolored glow kit
-Pioneer Bluetooth Head Unit
-Replaced all the speakers with Kicker 300 watt RMS
-Painted door speaker covers
-15% Tint all of the rear, and 30% tint on front +6" strip of tint on windshield
-Suede shifter boot with red stitching
-Aftermarket shifter ****
-Black mesh grill
Still to do:
-Driver race seat mount
-Tail Lights Si (Broken and leaking currently)
-Head Lights (Broken turn signals)
-Master Brake Cylinder (Slight pumping needed because of dirt in line)
-F20B DOHC Engine and LSD Tranny
-Interior Dash Remin aluminum kit
-Mini Door Interior lights replace (Getting dim)
-Lower it
-Mini Mic for stereo (For phone)
-Replace rotors
-Rear drum brakes paint black
-Bigger Calipers?
-Dash clock fix? (Dimming in and out)
-Apolster rear seat
-Apolster headliner
-Exhaust for good sounds with magna flow cats and muffler (No fart cannon)
-Cold air intake
Some pictures of what I've done:
https://scontent-b-dfw.xx.fbcdn.net/...22683498_o.jpg
https://scontent-a-dfw.xx.fbcdn.net/...26718426_o.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...18621715_o.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...70251622_o.jpg
https://fbcdn-sphotos-g-a.akamaihd.n...30220317_o.jpg
https://fbcdn-sphotos-a-a.akamaihd.n...81042853_o.jpg
https://fbcdn-sphotos-e-a.akamaihd.n...33566164_o.jpg
https://scontent-b-dfw.xx.fbcdn.net/...63662769_o.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...59689971_o.jpg
https://fbcdn-sphotos-b-a.akamaihd.n...d7c855af5ed030
https://fbcdn-sphotos-d-a.akamaihd.n...52082234_o.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...71687689_o.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...81532373_o.jpg
https://scontent-a-dfw.xx.fbcdn.net/...11586796_o.jpg
Last edited by Datechmaster; Apr 10, 2015 at 10:35 PM. Reason: Changed mind on if I want to do an F20b swap or not
Old Oct 5, 2014 | 07:51 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1992 Honda Accord f22 to f20b DOHC swap build/Help???
Originally Posted by Datechmaster
Will it mount up with the stock engine mounts? It should since it's an F series.
It will be similar to when swapping to an H22. Look in the Accord FAQ at the top of the page for swap info.
Old Oct 6, 2014 | 06:10 PM
Just went through a lot of posts. Nothing really answering if it's a direct swap with engine mounts, A/C, and Power steering. Those are the main thing's I'm worried about.
Old Nov 2, 2014 | 07:30 AM
Bump
Does any one know anything on if I can keep my A/C+Power Steering. Or suggestions on a specific turbo for the f20b Dohc with low compression pistons.
Old Apr 10, 2015 | 10:30 PM
Update on what I've done:
-Painted the center console black with plastic bonding paint
-Painted the headlight housings inside black accents
-Led wrap around inside of the headlights (Always running)
-Corner Lights clear with black casing
Center console
headlight before accent painting
after painting
after painting
after painting
Corner lights
leds
leds
Old Apr 11, 2015 | 03:17 AM
Mikhail's Avatar
To have power steering set up right (though you can use your old setup with a certain size belt), you should go to the JY and pick up a H23/H22 pw steering bracket along with its hose. That way it will be flush and won't make your hood rattle when driving down the road.
AC you can use your setup. Nothing special there. If you want to convert from OBD I to OBD II, its fairly simply. Get some OBD I H22 injectors or use your own with a FPR (I think you can do this fairly easily), along with a OBD I H22 ECU. The top half of the intake manifold will have to be changed to a H23 or H22 OBD I version so that you can use your IACV with the 2 wires instead of 3.
The front engine mount bracket will have to be changed; use your original bracket and bolts.
Fairly simple swap. You really shouldn't be swapping this tho unless you custom tune it out, the 2.0 liter engine is fairly small to put in a heavy chassis like an Accord and keep stock. But, if you want a sporty, low priced, fresh engine to put in your beater, its good choice.
Old Apr 13, 2015 | 07:46 AM
Thanks for the feed back Mikhail, I'm now contemplating keeping my f22a4 or just getting a spare one to build up the internals on and boost it instead. Might be easier and possible cheaper?
Old Apr 15, 2015 | 07:46 AM
Mikhail's Avatar
Boost will not be cheaper than running a H22a if you want to do it right, about 500-1000 more I would say, and you need a good tune too. The next best thing to boost is the H22 or H23 Vtec engine. I plan on hopefully getting a H23 Vtec put into my accord, being an upgrade from my F23 hyrbid build (which is very low cost btw and good torque).
If you want to go NA F22 or F23, that is also a good option. These engines perform very well tuned with a good cam and intake/exhaust/fuel and tune. F23 bottom end is better though because of the bigger stroke/torque. There's a guy called JDMAccorn on the Cb7tuner forum who runs a F23 hybrid motor (F23 block F22a head) making amazing torque numbers. Check his thread: http://cb7tuner.com/vbb/showthread.p...22#post3230722
Old Apr 15, 2015 | 07:51 AM
Mikhail's Avatar
But I would totally boost the F motor if I knew a tuner or had the extra dough.
Old Apr 16, 2015 | 08:15 AM
vandenberg369's Avatar
hello all, I just bought a 5spd 92 honda accord and need info on the ignition wiring. I have keys but it looks like it was ran with wiring to the starter (white+black) back to fuse box. I ran over a bunch of bumps in rd and the car just went off while driving. I moved the wires beneath my legs by clutch and started working again, however alot more bumps let to stop working. I see some tape came undone, does anyone know how to rewire so it will start direct?. jdvandenberg369@hotmail.com
nexuslite
Jul 9, 2010 11:10 PM
d-rail
Oct 7, 2008 05:02 AM
NWP4LIFE
Sep 8, 2008 01:50 AM
VRD^don
Nov 2, 2004 03:03 PM
