Problem with skunk2 cams stage 2 PLEASE HELP!!!
Old Nov 1, 2002 | 10:44 AM
00BuMSiR's Avatar
Default Problem with skunk2 cams stage 2 PLEASE HELP!!!
i had a alot of head work done and installed all new valvetrain. I installed the skunk2 stage 2 cams and now it runs slower. When vtec normally hits at 5500 rpm the car just doesn't go anywhere. It makes a LOUD vtec sound but it doesn't go anywhere until 6700 rpm and pulls hard until rev limiter. So i bought a vtec contoller to adjust fuel but i still have the same problem. i cant figure it out why it just boggs and 5500 rpms. please help.
Old Nov 1, 2002 | 10:46 AM
RenoRacing's Avatar
Default Re: Problem with skunk2 cams stage 2 PLEASE HELP!!! (00BuMSiR)
double check both your cam timing and your distributor timing, sounds like it's to retarded maybe.
Old Nov 1, 2002 | 10:50 AM
Katman's Avatar
if you didnt know, Sk2 Stage2 cams need to have vtec kick on around 6000rpm or higher. You should really go visit a dyno and get your car tuned with those cams.
Old Nov 1, 2002 | 11:01 AM
00BuMSiR's Avatar
Default Re: Problem with skunk2 cams stage 2 PLEASE HELP!!! (Katman)
i dont know why they have to have vtec around 6000. maybe its b/c of the high lift and longer duration but i can just all fuel to that.
Old Nov 1, 2002 | 11:08 AM
Katman's Avatar
...you're seeing the light now!
Old Nov 1, 2002 | 11:25 AM
Austin's Avatar
Go and visit a competent tuner...you'll be amazed at how the car runs afterwards.
Austin
Old Nov 3, 2002 | 10:09 AM
00BuMSiR's Avatar
Default Re: Problem with skunk2 cams stage 2 PLEASE HELP!!! (Austin)
everyone says to convert to obd1 but i dont want to. i have no money haha.
austinwasthere
Jun 17, 2014 11:58 AM
12secLSvtec
11
May 20, 2004 12:04 PM
Red D Dragon
16
May 14, 2004 07:37 AM
Mover
Apr 8, 2003 11:52 AM
KamikazeRacinz
Sep 9, 2002 06:29 AM
