Mk2 bushings
Old Oct 2, 2014 | 09:31 PM
br8crumb's Avatar
Default Mk2 bushings
figure while im doing a ITR swap on my 91 crx... should probably take care of the bushings all the way around especially the trailing arms that are non exsistant.
what brand and material bushings do you guys use?
Old Oct 2, 2014 | 11:23 PM
whited's Avatar
CRX God
Default Re: Mk2 bushings
Depends on your budget and what your looking for.
OEM style replacements will give you the stiffness back but it isn't as stiff as the next options.
Energy Bushings will give you a lot stiffer ride, but they sometimes are noisy and squeak.
Spherical is the most expensive, and will give the ultimate stiffness. These have the problem of parts twisting though, when they are not suppose too.
Usually with EFs people will stiffen the back up and leave the front alone, or even remove the front sway bar.
BSM 135i
Acura TSX
Oct 28, 2010 04:44 AM
wesley_925
Suspension & Brakes
Jul 4, 2008 06:20 PM
eyeballs
Sep 24, 2007 09:04 AM
JunIntegra
Suspension & Brakes
Jan 22, 2005 08:19 PM
RevEJ1
Oct 9, 2003 05:56 PM
