Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Bushing replacement
Old Oct 9, 2003 | 01:00 PM
RevEJ1's Avatar
Default Bushing replacement
I was planning on replacing some bushings when I install my anti-roll bar and was wondering what peoples opinions were on replacement urethane bushings. I'd be replacing the front tie rod end bushings (tie rods ends are shot), LCA bushings, and probably the sway bar bushings. Now my car is a daily driver, what are the pros and cons of replacing them with urethane vs. regular rubber bushings? Are the trade-offs worth it?
Old Oct 9, 2003 | 04:11 PM
Mike P.'s Avatar
25 Year Member
Default Re: Bushing replacement (RevEJ1)
I'd personally stick with OEM. The squeaking alone would be reason enough for me to not use poly bushings, especially since you say it's a daily driver.
Old Oct 9, 2003 | 05:10 PM
jc836's Avatar
The poly bushings will squeak if not heavily lubed when first installed. Keep them greased with silicone grease and they are reasonable even on a dialy driver.
Old Oct 9, 2003 | 05:56 PM
StyleTEG's Avatar
Default Re: Bushing replacement (jc836)
A few people have told me that using teflon tape instead of greesing prevents squeeking and doesn't require the occational re-greasing.
Anyone tried this?
boxedfox
Suspension & Brakes
Apr 22, 2018 10:35 AM
wesley_925
Suspension & Brakes
Jul 4, 2008 06:20 PM
JunIntegra
Suspension & Brakes
Jan 22, 2005 08:19 PM
xci_ed6
32
Dec 12, 2003 06:48 AM
ragejed
Sep 25, 2002 04:40 PM
