Need some help w/ Gauge Cluster
Old Oct 2, 2014 | 12:34 PM
JonasG93's Avatar
Default Need some help w/ Gauge Cluster
It works just fine until the lights get turned on at night. After the lights are turned on all needles fall down and both blinker start flashing but arent actually being blinked. I need help on where to start on diagnosing this. Thanks.
Its a 1993 Honda Del Sol D16Z6.
Old Oct 2, 2014 | 10:59 PM
Grant12978's Avatar
Default Re: Need some help w/ Gauge Cluster
I would buy a cheap cluster from a junkyard replace and see if that solves it... I pay 30$ for clusters and it's only 6 screws so it's easy. If the cluster work we know it's a cluster problem easily fixed most likely. If it's still acting goofy you can sell your new used cluster for a profit on ebay or here and we can diagnose more. But that's an easy cheap place to start.
Old Jan 30, 2015 | 04:38 PM
JonasG93's Avatar
Find me a cluster for an automatic 93 del sol si for $30 and let me know! lol
Im having the hardest time finding them down here in Texas.
I also find out when light are on and I get my speed up to around 50mph the cluster will start freaking out like it wants to turn on.
Old Jan 30, 2015 | 05:24 PM
Former User's Avatar
Check all the grounds in the engine bay and in the rear. Sounds like one is bad.
Old Jan 30, 2015 | 06:24 PM
JonasG93's Avatar
Is there a diagram showing where they are at?
Old Mar 15, 2015 | 10:43 AM
JonasG93's Avatar
Can you test grounds with a fuse tester?
Old Mar 15, 2015 | 10:46 AM
Yes --> continuity to body ground.
Old Mar 15, 2015 | 10:48 AM
How could anybody tell you. You failed to provide required car information in your first post -- add it there.
Old Mar 16, 2015 | 04:42 PM
JonasG93's Avatar
Sorry updated now.
Old Mar 17, 2015 | 09:40 AM
JonasG93's Avatar
Also i'd like to learn how the grounds in the engine bay would affect the instrument cluster lights?
Old Mar 19, 2015 | 01:30 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
^ Basically, your car electrics like to go to ground through the easiest route. This would be the ground wire. But there are other parts on your car electrics that can also function as a ground, and not having a ground wire can either cause a part not to work, or cause all sorts of seemingly unrelated things to go bananas because it's grounding where it's not supposed to. This is what's likely happening in your case.
Old Mar 19, 2015 | 03:41 PM
Originally Posted by deschlong
bananas
I officially declare this^ excellent word underused in this forum.
taterguy05
Acura TL, RL & ZDX
Jul 18, 2010 11:31 PM
bluestd
May 18, 2010 09:43 PM
DelSolMarine
14
Feb 7, 2006 08:07 AM
StevesSol
Jan 27, 2003 03:09 PM
