Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Left map light doesn't work when opening door
Old Oct 1, 2014 | 07:45 AM
cvanderhoef's Avatar
Default Left map light doesn't work when opening door
I have a 2008 Pilot where the drivers side map light doesn't turn on when opening the door but turns on if I manually do it. I believe there is a switch that is not working correctly. Is the switch in the door or in the console where the lights are? Any idea on how to remove the light console if it is above the console? Thanks.
Old Oct 1, 2014 | 10:56 AM
Default Re: Left map light doesn't work when opening door
Found it and fixed! Two screws in the sunglass holder and a screw under each light cover. The unit just drops down after the 4 screws are removed. Removed the Homelink module, pulled the switch out, cleaned the contacts and now it works!
Old Oct 23, 2014 | 10:29 AM
shad295's Avatar
Dang! I could've saved my self $100, that's what they charged me (the dealer).
woj
Feb 13, 2018 06:17 AM
hon0405
Dec 7, 2016 01:29 PM
19Accord97
Mar 9, 2012 04:50 PM
builthatch
Honda Civic (2006 - 2015)
Jan 1, 2012 08:15 AM
nemesis25
Oct 12, 2008 08:27 PM
