Eg 92 Fuel problem NOT STARTING
Old Sep 30, 2014 | 07:57 PM
Arm4nii's Avatar
Default Eg 92 Fuel problem NOT STARTING
So I just got a new fuel pump main relay and spark plugs. When I first try to start the car it turns over and I don't hear the fuel pump prime. And it will just keep turning over .and once the fuel pump primes .the car will start fine but the next day I have the same problem does anyone know what this could be
Old Oct 1, 2014 | 09:14 PM
mussa24's Avatar
Default Re: Eg 92 Fuel problem NOT STARTING
CHECK THE CURRENT TO YOUR PUMP MAKE SURE ITS WELL GROUNDED ALSO CHECK FUEL TANK FOR SEDIMENTS LARGE VOLUMES OF SEDIMENT CAUSES PUMP TO STICK MOST OF THE TIMES U CAN CHECK BY LIFTING THE SEAT AND PUTTING A FEW KNOCKS ON THE COVER NOT REAR FOR A CAR OF ITS AGE
Old Oct 4, 2014 | 08:56 PM
hybridmiklo's Avatar
like mussa said. Also inspect the fuel pump strainer to make sure its not bent or obstructing in some way.
Old Oct 7, 2014 | 08:11 PM
pythoner's Avatar
My del sol is doing the same thing. I have been told that it is because the electrical load detector is bad. I also have the lovely thing where a previous owner cut up my ecu harness though.
teknohatchie91
Apr 15, 2009 11:40 AM
arospeedintegra
Mar 6, 2007 02:26 PM
deckster333
Sep 10, 2006 10:43 AM
AcidFr33ze
Aug 7, 2005 10:21 AM
