does oil pressure sending unit throw a code?
Old Sep 25, 2014 | 07:34 PM
raverx3m's Avatar
Default does oil pressure sending unit throw a code?
do I have to have it hooked up or can I install a gauge instead?
I want to have a permanent oil pressure gauge instead of the stock sending unit cuz its kinda useless.
but was wondering if the ecu needs it for anything at all to run properly?
Old Sep 25, 2014 | 08:30 PM
n/a2boost's Avatar
Default Re: does oil pressure sending unit throw a code?
No code. It's just a light in the cluster.
Old Sep 26, 2014 | 11:01 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
They call them idiot lights for a reason... they don't talk to the computer. No, not even the temperature gauge sending unit. The cluster is all outputs coming in to be input into the cluster. Talk about a cluster...
Old Sep 26, 2014 | 06:05 PM
raverx3m's Avatar
nice. done with that sht lol it already cost me one engine
Old Sep 27, 2014 | 03:42 PM
DO IT ON ALL FOURS
IIRC it is set to come on at 5 psi. By that time your engine is long gone. The only time it is of benefit is if your clearances are so bad at idle that your oil pressure drops down, but even then you are in need of a major overhaul.
jasongeist
Apr 14, 2011 11:03 PM
crxjarred
Jun 16, 2010 10:24 AM
Audi RS4
Mar 9, 2004 05:20 PM
1.8T_EG
Apr 18, 2003 08:00 AM
sir2chad
Apr 16, 2003 04:10 AM
