Dash Lights
Old Sep 25, 2014 | 07:01 AM
DakottaSchumm's Avatar
Default Dash Lights
I have a 2000 Honda Civic lx and my Dash lights and the lights that light up my center console dont come on when i turn on my lights. However sometimes they do. The fuse is not blown and the dimmer switch is okay. I was reading somewhere that if you get a new radio it could make this happen. Anyone have any ideas? thanks!
Old Sep 25, 2014 | 08:23 AM
tony_2018's Avatar
Fish Twig
Default Re: Dash Lights
So do you have a new radio?
Old Sep 25, 2014 | 09:09 AM
Yes I do.
Old Sep 25, 2014 | 11:55 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
How did you check the dimmer switch? Did you do this?
Old Sep 25, 2014 | 04:22 PM
Yeah and everything was fine. When the lights do come back in the dimmer switch works.
Old Sep 25, 2014 | 08:18 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
If you installed an aftermarket radio and hooked up the car's small light illumination Red/Blk wire (+) and Red wire (-) to the radio; then disconnect them, as that may be causing your issue.
- Red/Blk is a red colored wire with a black stripe running through it, that is the small lights power (+) wire and only should have power when the headlight switch is turned to Park or Headlight.
- Red wire is ground (-) which the dimmer switch controls by varying the resistance when you turn the ****. The higher the resistance, less ground (-) current goes through and the lights are dimmed. The lower the resistance, more ground (-) current goes through and the lights are brighter.
greg51
22
Feb 13, 2015 10:54 AM
bubblebrain
Nov 24, 2012 05:41 PM
wutupnut
Audio / Security / Video
14
Apr 8, 2008 04:27 PM
d16efsedan
Apr 23, 2005 05:38 PM
