Fuel filter catastrophe
Old Sep 24, 2014 | 08:55 PM
Jaxis's Avatar
Default Fuel filter catastrophe
So I decide it's been 10 years. It's time to change the fuel filter. While disconnecting the battery my socket wrench touched the positive terminal. Sparks flew. Finished the replacement. reconnected the battery, turn the key and... nothing happens.
I know fuel pump and all other electronics work when power on. Checked all the fuses I could, nothing blew.
You think I fried my starter solenoid? Or something worse?
Old Sep 25, 2014 | 12:05 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Fuel filter catastrophe
Get a multimeter and see what voltage your battery is holding. You may have just drained the battery past being able to start the car.
Old Sep 25, 2014 | 11:28 PM
Jaxis's Avatar
Yup, battery is good and charge. Still nothing. sad day
Old Sep 25, 2014 | 11:41 PM
NotARaCist's Avatar
Then check your main battery fuse/relay. It's in the under-hood fuse box, but it's one of the HUGE ones, not one of the smaller fuses.
Old Oct 1, 2014 | 12:31 PM
Jaxis's Avatar
I replaced the starter. Autozone said it was bad and was under warranty. However this didn't fix the problem. Guess what. The plastic clutch switch stopper broke. Now trying to figure out how to replace this without removing the clutch pedal. Any ideas people?
Old Oct 1, 2014 | 12:47 PM
angrysmileyface's Avatar
Yes, there are several threads on this. My experiance was to use a small loop of wire around it to guide it into place and use a flat head screwdriver to push it down.
Old Oct 1, 2014 | 12:58 PM
EsotericImage's Avatar
Retired Moderator
I just had mine fall apart last week..
I went to honda, it was 2.89ea for 2 pads.
I used a lollipop that was half *** melted, Rubbed my index finger on it, got it sticky to hold the little plastic pad. Reached up into the pedal and snapped it in place. Took me all of 2 mins.
Its pretty easy to find. Hows that for some tech!
Old Oct 1, 2014 | 02:09 PM
Jaxis's Avatar
Mine was a little more difficult. I used a large flat head screw driver and doubled sided tape. Had my wife press the clutch down as needed. Thanks for the tips guys
sdots24
Honda Motorcycles
Dec 16, 2011 09:41 AM
dc2teg2006
Mar 28, 2009 05:31 PM
seamus657
Mar 6, 2009 08:47 PM
Tip14
Dec 27, 2007 01:13 PM
b20vtecEK
Apr 5, 2005 11:45 PM
