B16a2 not running when hot.
I've been having a lot of problems with my motor.
When I start up from cold, it's fine. Good idle and revs smooth.
When I take it out for a test drive, after a few minutes, I notice it starts to hesitate when I press the gas.
It gets worse and worse, so that after a couple more minutes, the car won't drive. I can't press the gas without the car popping, misfiring and stalling. Then it just won't start.
It seems like fuel starvation to me, but the pump is new.
I've tried new injectors, iacv, inlet temp sensor, lambda.
No cel.
Any ideas?
No cel.
Any ideas?
Re: B16a2 not running when hot.
The car gets up to operating temp, not overheating.
No major Mods - alloy fuel tank.
Walbro 225 LPH external fuel pump.
Aem fuel pressure regulator.
4-1 manifold
Stainless exhaust - no cat
Lightweight flywheel.
No cel.
Not touched mechanical timing, but set ignition timing. New fluids, filters, plugs, distributor, leads.
4-1 manifold
No cel.
I am having the same problem in my crx b16a2. I unplugged. the primary o2 sensor and it still didn't work. When it was cold it will idle at 1000 rpm but when it hits 150 on the temp guage it revs up to 1.2 rpm, revs higher then dies down like its about to run out of gas and the idles back up to 1.2 rpm. I've tried the fuel injectors, fuel pump, all the plug sensors on the throttle body.
ChristianEJ6
10-07-2015 09:55 AM
teg racer 877
04-07-2010 09:53 PM
