civic 2000 exr hard start when hot
Old Sep 23, 2014 | 01:23 PM
kenlider's Avatar
Default civic 2000 exr hard start when hot
Every day by mornings it starts withtout a problem, but once the car is hot, and y got an stop at least for 5 minutes, the car just dont want to start, i have cleaning the iac valve, fuel filter, air filter, also soldering the main relay, and the problem persist, i´ve seen many post of people with this problem but, nobody clarifies if it was solved or not, i hope you can help me, i've burned my brain
Old Sep 27, 2014 | 05:28 PM
kenlider's Avatar
Default Re: civic 2000 exr hard start when hot
anyone pls
Old Sep 28, 2014 | 01:15 PM
DOHCtR-V's Avatar
What's a Civic "EXR"?
Civic with an F22 (from a Canadian Accord) swap?
Old Sep 28, 2014 | 07:52 PM
kenlider's Avatar
its a coupe version, with a d16y8 sohc motor
Old Sep 28, 2014 | 08:53 PM
Sleeping Perfor's Avatar
Every car made from 1996 and up have a crank sensor. That mean that as soon the crank sensor get ho its not sending the signal to start so you have to wait to do it. Make sure you buy it. Please before doing this job disconnect the ground.
Old Sep 28, 2014 | 08:58 PM
DOHCtR-V's Avatar
Ahhhh.....
Those are called EX (96-98), & SI (99-00) up here.
(Both SOHC)
Your Si/EM1/DOHC is called SIR up here.
EXR's are the top model for Accords 90-97 up here.
My bad.
So your car stalls once warm, & won't start or drive until it cools down?
Unrelated, but it deals with 1 of the parts listed:
I had rough cold starts, & this helped me.
If cleaning those parts don't help, try replacing the IVAC.
Old Sep 28, 2014 | 09:39 PM
kenlider's Avatar
do i need to buy the entire distributor? i cant find it separately!
i put my fans direct and it helps a little, it starts quicker
Old Sep 28, 2014 | 09:41 PM
kenlider's Avatar
Ahhhh.....
(Both SOHC)
My bad.
yeah if its warn it wont start, i need to wait a couple of minutes, any ideas, i have change gas pump, main relay is ok, temp sensor ok, timing its a little forward
Old Sep 29, 2014 | 12:51 PM
Please did you check the crank sensor.
File Type: pdf
Old Sep 30, 2014 | 06:32 PM
kenlider's Avatar
which sensor you reffer? The crank position sensor or the crank fluctuation sensor? The position sensor is in the distributor.
Old Sep 30, 2014 | 06:41 PM
Norlael's Avatar
he means the one on the oil pump, under the black plastic behind the main crank pulley. would be CKF sensor you want to check out. CKP is on the distributor shaft.
Old Sep 30, 2014 | 07:08 PM
kenlider's Avatar
ok, to get things clear, my d16y8 motor has the two sensors ckp on distributor and ckf under water pump, the one i need to change is the one on the bottom of water pump right? i mean this one
Sensor Ckp (de Posicion De Cigüeñal) Honda Civic 96-00; Sp0 - $ 510.00 en MercadoLibre
its kinda confusing because it says ckp but the real thing is that its a ckf sensor.
Old Sep 30, 2014 | 10:31 PM
stelvio's Avatar
Don't mean to threadjack, but isn't the main relay a common thing to cause hard starts in the heat with Hondas?
Old Oct 1, 2014 | 07:14 AM
kenlider's Avatar
yeah, but now its working fine main relay, i still cant find the solution
Old Oct 1, 2014 | 11:04 AM
stelvio's Avatar
Did you do regular maintenance things like sparkplugs, clean TB, oil, check for vacuum leaks, etc?
Old Oct 1, 2014 | 07:24 PM
kenlider's Avatar
Yeah, i change oil every, 3000-5000 km or every two monts, the time when i need to drive to my home city, sparkplugs every 25000 km, i recently clean the admission intake, vacum leaks is the only thing i dont know how to check.
i have read on some post that this problem might be because a failure cooling sensor, today i disconect this sensor and i start the engine without a problem, then put it back againt, and the failure was there, tomorrow i'll buy a new sensor and check if it solves my problem, i hope it will, pls cross fingers!!
Old Oct 2, 2014 | 04:35 PM
kenlider's Avatar
well guys, i finally solve my problem, it was the ect sensor, the way i realise that problem, was unplugging the conector and the car was starting with no problem, once i plug in againt it fails,
thanks for your help
uncommenartist
Classic Hondas
Jan 27, 2015 02:30 PM
shelleebella82
Mar 31, 2012 08:13 AM
needlesmcgirk
Apr 6, 2010 08:18 PM
xiong28
Nov 24, 2007 07:12 PM
kikacha
Jun 29, 2007 02:52 PM
